PNY GeForce GTX 770 XLR8 OC 2GB Review
September 27, 2013 | 09:06
Tags: #geforce #geforce-gtx #graphics-card #gtx-770 #xlr8
Companies: #pny
Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 2,560 x 1,600. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
Power consumption (idle)
Windows 7 Aero Desktop
  • Nvidia GeForce GTX 660 2GB
  • Nvidia GeForce GTX 770 2GB
  • AMD Radeon HD 7850 2GB
  • Nvidia GeForce GTX 780 3GB
  • Nvidia GeForce GTX Titan 6GB
  • AMD Radeon HD 7870 2GB
  • Nvidia GeForce GTX 660 Ti 2GB
  • Nvidia GeForce GTX 760 2GB
  • AMD Radeon HD 7970 3GB GHz Edition
  • AMD Radeon HD 7950 3GB with Boost
  • PNY GeForce GTX 770 XLR8 OC 2GB
  • Nvidia GeForce GTX 670 2GB
  • Nvidia GeForce GTX 680 2GB
  • Nvidia GeForce GTX 690 4GB
  • AMD Radeon HD 7990 6GB
  • 103
  • 104
  • 106
  • 108
  • 108
  • 108
  • 109
  • 110
  • 110
  • 110
  • 110
  • 111
  • 112
  • 122
  • 127
50
75
100
125
System Power Consumption in Watts
Power consumption (load)
Crysis 3 (2,560 x 1,600, 0x AA, Very High Settings)
  • 227
  • 243
  • 244
  • 266
  • 277
  • 295
  • 300
  • 314
  • 333
  • 341
  • 344
  • 352
  • 356
  • 415
  • 470
200
300
400
500
Thermal Performance (Idle and Gaming)
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
Heat (idle)
  • 6
  • 7
  • 7
  • 9
  • 10
  • 10
  • 10
  • 10
  • 11
  • 11
  • 11
  • 11
  • 12
  • 14
  • 14
  • 16
8
10.5
13
15.5
18
Delta T in °C
Heat (load)
Unigine Heaven Benchmark (2,560 x 1,600, default settings)
  • AMD Radeon HD 7970 3GB GHZ Editon
  • 40
  • 41
  • 43
  • 50
  • 52
  • 53
  • 54
  • 54
  • 54
  • 55
  • 55
  • 57
  • 57
  • 59
  • 59
  • 63
20
30
40
50
60
70
Delta T in °C
*as there's no stock model of the HD 7850 2GB, it is not included in these graphs
null
